Salta al contenuto principale
Asus Eee PC 900 Keyboard Replacement
Cosa ti serve
  1. Asus Eee PC 900 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Asus Eee PC 900 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Asus Eee PC 900 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Asus Eee PC 900 Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Asus Eee PC 900 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 Asus Eee PC 900 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed.
    • Identify the three metal tabs holding down the laptop's keyboard.
    • Using a spudger, depress each metal tab to remove the keyboard.
    • The upper part of the keyboard should "pop up" from its holder.
  4. Asus Eee PC 900 Keyboard Replacement: passo 4, immagine 1 di 2 Asus Eee PC 900 Keyboard Replacement: passo 4, immagine 2 di 2
    • Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
  5. Asus Eee PC 900 Keyboard Replacement: passo 5, immagine 1 di 1
    • Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
    • Slide the keyboard's ribbon cable from the connector.
  6. Asus Eee PC 900 Keyboard Replacement: passo 6, immagine 1 di 1
    • Remove the keyboard by lifting upwards.
Conclusione
Altre 12 persone hanno completato questa guida.
Sheldon Chu
Membro da: 01/24/12
1.099 Reputazione
3 Guide realizzate
Cal Poly, Team 3-27, Amido Winter 2012 Membro di Cal Poly, Team 3-27, Amido Winter 2012
CPSU-AMIDO-W12S3G27
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 39
Tutti i Tempi: 9,932
