Salta al contenuto principale
Asus Eee PC 1201N RAM Replacement
Cosa ti serve
  1. Asus Eee PC 1201N RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N RAM Replacement: passo 2, immagine 1 di 1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N RAM Replacement: passo 3, immagine 1 di 1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N RAM Replacement, RAM: passo 4, immagine 1 di 2 Asus Eee PC 1201N RAM Replacement, RAM: passo 4, immagine 2 di 2
    • Remove the two 4.6mm screws using the J0 Phillips head screwdriver.
    • Then use the plastic opening tool to open the RAM door.
  5. Asus Eee PC 1201N RAM Replacement: passo 5, immagine 1 di 1
    • Push the tabs on the side of the RAM to release.
    • Only push the tabs over slightly to ensure you do not break them.
  6. Asus Eee PC 1201N RAM Replacement: passo 6, immagine 1 di 1
    • Remove the RAM by pulling it towards you.
Conclusione
Trae Mikesell
Membro da: 10/04/16
394 Reputazione
3 Guide realizzate
USF Tampa, Team 2-3, Nance Fall 2016 Membro di USF Tampa, Team 2-3, Nance Fall 2016
USFT-NANCE-F16S2G3
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 960
