Salta al contenuto principale
Asus Eee PC 1201N Cooling fan replacement
Cosa ti serve
  1. Asus Eee PC 1201N Cooling fan replacement, Battery: passo 1, immagine 1 di 1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N Cooling fan replacement: passo 2, immagine 1 di 1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N Cooling fan replacement: passo 3, immagine 1 di 1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N Cooling fan replacement, Keyboard: passo 4, immagine 1 di 2 Asus Eee PC 1201N Cooling fan replacement, Keyboard: passo 4, immagine 2 di 2
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
  5. Asus Eee PC 1201N Cooling fan replacement: passo 5, immagine 1 di 2 Asus Eee PC 1201N Cooling fan replacement: passo 5, immagine 2 di 2
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
  6. Asus Eee PC 1201N Cooling fan replacement, Cooling fan: passo 6, immagine 1 di 1
    • Remove the eight 6.5mm screws using the J0 Phillips head screwdriver from back of the netbook.
  7. Asus Eee PC 1201N Cooling fan replacement: passo 7, immagine 1 di 2 Asus Eee PC 1201N Cooling fan replacement: passo 7, immagine 2 di 2
    • Remove the ten 4.5 mm screws from cover plate using the J0 Phillips head screwdriver.
    • Remove the cover plate by sliding the plastic opening tool around the entire edge of the plate.
  8. Asus Eee PC 1201N Cooling fan replacement: passo 8, immagine 1 di 1
    • Pull the blue tab for the touchpad connector before removing the cover plate completely.
  9. Asus Eee PC 1201N Cooling fan replacement: passo 9, immagine 1 di 1
    • Remove the two 4.6 mm screws from the cover plate using the J0 Phillips head screwdriver.
  10. Asus Eee PC 1201N Cooling fan replacement: passo 10, immagine 1 di 1
    • Unplug the connector.
  11. Asus Eee PC 1201N Cooling fan replacement: passo 11, immagine 1 di 1
    • Lift up and remove the fan.
Conclusione
USF Tampa, Team 2-3, Nance Fall 2016 Membro di USF Tampa, Team 2-3, Nance Fall 2016
USFT-NANCE-F16S2G3
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 928
