Salta al contenuto principale
Asus Eee PC 1015PN motherboard dismantling (English)
Cosa ti serve
  1. Asus Eee PC 1015PN  motherboard dismantling (English), Motherboard: passo 1, immagine 1 di 2 Asus Eee PC 1015PN  motherboard dismantling (English), Motherboard: passo 1, immagine 2 di 2
    • To remove the battery, unlock the marked tabs.
  2. Asus Eee PC 1015PN  motherboard dismantling (English): passo 2, immagine 1 di 3 Asus Eee PC 1015PN  motherboard dismantling (English): passo 2, immagine 2 di 3 Asus Eee PC 1015PN  motherboard dismantling (English): passo 2, immagine 3 di 3
    • To remove the memory, lift the plastic tab covering the memory screw with a small slot head screwdriver.
  3. Asus Eee PC 1015PN  motherboard dismantling (English): passo 3, immagine 1 di 2 Asus Eee PC 1015PN  motherboard dismantling (English): passo 3, immagine 2 di 2
    • Lift the plastic cover and remove the SO-DIMM module.
  4. Asus Eee PC 1015PN  motherboard dismantling (English): passo 4, immagine 1 di 2 Asus Eee PC 1015PN  motherboard dismantling (English): passo 4, immagine 2 di 2
    • Remove the dummy SD-Card
  5. Asus Eee PC 1015PN  motherboard dismantling (English): passo 5, immagine 1 di 2 Asus Eee PC 1015PN  motherboard dismantling (English): passo 5, immagine 2 di 2
    • Unscrew 4 screws that are located in the battery compartment. Once removed, plastic tabs need to be removed on the upper part.
  6. Asus Eee PC 1015PN  motherboard dismantling (English): passo 6, immagine 1 di 2 Asus Eee PC 1015PN  motherboard dismantling (English): passo 6, immagine 2 di 2
    • With an extraction tool, separate the keyboard chassis from the netbook, it has many tabs.
  7. Asus Eee PC 1015PN  motherboard dismantling (English): passo 7, immagine 1 di 2 Asus Eee PC 1015PN  motherboard dismantling (English): passo 7, immagine 2 di 2
    • While separating the keyboard chassis, be careful with the keyboard connector. To remove it, simply slide the plastic retainer to be able to free it.
  8. Asus Eee PC 1015PN  motherboard dismantling (English): passo 8, immagine 1 di 2 Asus Eee PC 1015PN  motherboard dismantling (English): passo 8, immagine 2 di 2
    • Unscrew the marked screws. One of those screws is behind a warranty sticker.
  9. Asus Eee PC 1015PN  motherboard dismantling (English): passo 9, immagine 1 di 2 Asus Eee PC 1015PN  motherboard dismantling (English): passo 9, immagine 2 di 2
    • Disconnect the mouse connector. The connector has a white plastic tab that disconnects the connector.
  10. Asus Eee PC 1015PN  motherboard dismantling (English): passo 10, immagine 1 di 3 Asus Eee PC 1015PN  motherboard dismantling (English): passo 10, immagine 2 di 3 Asus Eee PC 1015PN  motherboard dismantling (English): passo 10, immagine 3 di 3
    • With a flat screwdriver, release two plastic tabs ( 1 on each side), and with pressure in the front, release the chassis.
  11. Asus Eee PC 1015PN  motherboard dismantling (English): passo 11, immagine 1 di 2 Asus Eee PC 1015PN  motherboard dismantling (English): passo 11, immagine 2 di 2
    • To disconnect the hard drive, two connectors need to be removed, pay attention to the connectors sides, the one on the left in marked as MB and the right is marked as IO.
  12. Asus Eee PC 1015PN  motherboard dismantling (English): passo 12, immagine 1 di 3 Asus Eee PC 1015PN  motherboard dismantling (English): passo 12, immagine 2 di 3 Asus Eee PC 1015PN  motherboard dismantling (English): passo 12, immagine 3 di 3
    • Remove the screws, and slide the hard drive free.
  13. Asus Eee PC 1015PN  motherboard dismantling (English): passo 13, immagine 1 di 1
    • Disconnect the motherboard connector and the IO plate.
  14. Asus Eee PC 1015PN  motherboard dismantling (English): passo 14, immagine 1 di 2 Asus Eee PC 1015PN  motherboard dismantling (English): passo 14, immagine 2 di 2
    • Remove the fan connector, the BIOS battery and the upper connector.
  15. Asus Eee PC 1015PN  motherboard dismantling (English): passo 15, immagine 1 di 3 Asus Eee PC 1015PN  motherboard dismantling (English): passo 15, immagine 2 di 3 Asus Eee PC 1015PN  motherboard dismantling (English): passo 15, immagine 3 di 3
    • Remove the plate screws and release the screen connector.
  16. Asus Eee PC 1015PN  motherboard dismantling (English): passo 16, immagine 1 di 2 Asus Eee PC 1015PN  motherboard dismantling (English): passo 16, immagine 2 di 2
    • Remove the motherboard from the chassis, and disconnect a connector that is glued.
Conclusione
Altre 6 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
es en
100%
DeZom ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
2 Commenti
Joder la que hay que liar para cambiar el disco duro.
Rafael Belmonte - Replica
Thank you for the guide
ilcaccillo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 55
Tutti i Tempi: 13,714
