Salta al contenuto principale
Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement
Cosa ti serve
  1. Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement, Trackpad Mouse Clicker (the button's on the bottom of the trackpad): passo 1, immagine 1 di 1
    • Use an opening too to carefully separate the palm rest assembly from the base of the laptop.
    • Move the opening tool around the perimeter of the palm rest and the base and use it as a wedge.
    • You will need to undo the clips holding the two parts together with the opening tool. Be careful not to break the clips.
  2. Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement: passo 2, immagine 1 di 2 Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a spudger to open the cable locks and remove the ribbon cables using your hands or tweezers.
    • Using a Phillips #00 screwdriver, remove the two 4 mm screws on either side of the circuit board.
Conclusione
Cal Poly, Team 21-52, Johann Spring 2013 Membro di Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 904
