Salta al contenuto principale
Asus Eee PC 1008ha Screen Replacement
Cosa ti serve
  1. Asus Eee PC 1008ha Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Screen Replacement: passo 2, immagine 1 di 3 Asus Eee PC 1008ha Screen Replacement: passo 2, immagine 2 di 3 Asus Eee PC 1008ha Screen Replacement: passo 2, immagine 3 di 3
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Screen Replacement: passo 3, immagine 1 di 2 Asus Eee PC 1008ha Screen Replacement: passo 3, immagine 2 di 2
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Screen Replacement, LCD Screen: passo 4, immagine 1 di 2 Asus Eee PC 1008ha Screen Replacement, LCD Screen: passo 4, immagine 2 di 2
    • Using the Phillips #00 screwdriver, unscrew the 4mm screws from the rightmost circuit board.
    • Carefully pull the circuit board away from side of device base.
  5. Asus Eee PC 1008ha Screen Replacement: passo 5, immagine 1 di 3 Asus Eee PC 1008ha Screen Replacement: passo 5, immagine 2 di 3 Asus Eee PC 1008ha Screen Replacement: passo 5, immagine 3 di 3
    • Using the Phillips #00 screwdriver, unscrew the 4mm screws attaching screen to base from both sides.
    • Gently lift the screen portion from the base.
  6. Asus Eee PC 1008ha Screen Replacement: passo 6, immagine 1 di 2 Asus Eee PC 1008ha Screen Replacement: passo 6, immagine 2 di 2
    • Using the Plastic Opening Tool, pry the six small chits from the face of the screen portion.
    • Using the Phillips #00 screwdriver, unscrew the two 2mm and four 4mm screws from underneath the chits.
  7. Asus Eee PC 1008ha Screen Replacement: passo 7, immagine 1 di 2 Asus Eee PC 1008ha Screen Replacement: passo 7, immagine 2 di 2
    • Slide the Plastic Opening Tool under the edge of the screen bezel to release the front panel of the screen.
  8. Asus Eee PC 1008ha Screen Replacement: passo 8, immagine 1 di 2 Asus Eee PC 1008ha Screen Replacement: passo 8, immagine 2 di 2
    • Using the Phillips #00 screwdriver, unscrew the 2mm screws from the perimeter of the screen.
    • Use your fingers to hold the screen and carefully lift it from the base.
  9. Asus Eee PC 1008ha Screen Replacement: passo 9, immagine 1 di 2 Asus Eee PC 1008ha Screen Replacement: passo 9, immagine 2 di 2
    • Use your fingers to peel back the adhesive tape located on the back of the screen.
    • Disconnect the wire from the screen.
Conclusione
Cal Poly, Team 21-52, Johann Spring 2013 Membro di Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,059
