Salta al contenuto principale
Asus Eee PC 1008ha Graphics Card Replacement
Cosa ti serve
  1. Asus Eee PC 1008ha Graphics Card Replacement, Battery: passo 1, immagine 1 di 1
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Graphics Card Replacement: passo 2, immagine 1 di 3 Asus Eee PC 1008ha Graphics Card Replacement: passo 2, immagine 2 di 3 Asus Eee PC 1008ha Graphics Card Replacement: passo 2, immagine 3 di 3
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Graphics Card Replacement: passo 3, immagine 1 di 2 Asus Eee PC 1008ha Graphics Card Replacement: passo 3, immagine 2 di 2
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Graphics Card Replacement, Graphics Card: passo 4, immagine 1 di 1
    • Remove the two 2mm screws from the graphics card.
  5. Asus Eee PC 1008ha Graphics Card Replacement: passo 5, immagine 1 di 3 Asus Eee PC 1008ha Graphics Card Replacement: passo 5, immagine 2 di 3 Asus Eee PC 1008ha Graphics Card Replacement: passo 5, immagine 3 di 3
    • Flip over the graphics card.
    • Pull the black plastic locking mechanism towards the golden ribbon to unlock.
    • Pull out the ribbon.
Conclusione
Alex Powers
Membro da: 04/17/13
101 Reputazione
2 Guide realizzate
Cal Poly, Team 21-52, Johann Spring 2013 Membro di Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Membri
11 Guide realizzate
Un commento
Is this the graphics card?
Is this pc has no integrated graphics card?
JUAN LUIS GARCIA BRAVO - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 3,608
