Salta al contenuto principale
Asus Eee PC 1008ha Cooling Fan Replacement
Cosa ti serve
  1. Asus Eee PC 1008ha Cooling Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Cooling Fan Replacement: passo 2, immagine 1 di 3 Asus Eee PC 1008ha Cooling Fan Replacement: passo 2, immagine 2 di 3 Asus Eee PC 1008ha Cooling Fan Replacement: passo 2, immagine 3 di 3
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Cooling Fan Replacement: passo 3, immagine 1 di 2 Asus Eee PC 1008ha Cooling Fan Replacement: passo 3, immagine 2 di 2
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Cooling Fan Replacement, Cooling Fan: passo 4, immagine 1 di 3 Asus Eee PC 1008ha Cooling Fan Replacement, Cooling Fan: passo 4, immagine 2 di 3 Asus Eee PC 1008ha Cooling Fan Replacement, Cooling Fan: passo 4, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the two 2mm screws from the copper heat sink. These are found on the left side of the device.
    • Make sure to remove the adhesive tape from the top of the heat sink.
  5. Asus Eee PC 1008ha Cooling Fan Replacement: passo 5, immagine 1 di 2 Asus Eee PC 1008ha Cooling Fan Replacement: passo 5, immagine 2 di 2
    • Remove the small white connector attached to the fan. Make sure to carefully pull from the white connector. Do not pull the connecting wires, as this can cause damage to the component.
    • Replace with new cooling fan!
Conclusione
To reassemble your device, follow these instructions in reverse order. If your device is still having issues after replacing the cooling fan, ensure the device is powered off and carefully follow this guide from the beginning; you may have misplaced something. We hope this guide has served as a helpful resource in replacing your Asus Eee PC 1008ha cooling fan!
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 21-52, Johann Spring 2013 Membro di Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,727
