Salta al contenuto principale
Asus Eee PC 1005PEB RAM Replacement
Cosa ti serve
  1. Asus Eee PC 1005PEB RAM Replacement, RAM: passo 1, immagine 1 di 2 Asus Eee PC 1005PEB RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Start by having the laptop upside down on a hard flat surface.
    • Find and unscrew the 6.65 mm Phillips #1 screw.
    • The screw will not detach from the RAM cover.
  2. Asus Eee PC 1005PEB RAM Replacement: passo 2, immagine 1 di 2 Asus Eee PC 1005PEB RAM Replacement: passo 2, immagine 2 di 2
    • Carefully remove the cover by lifting it with your fingers.
    • Make sure that you do not pull the cover to quickly or too hard as this could damage the plastic pins that hold the cover on.
  3. Asus Eee PC 1005PEB RAM Replacement: passo 3, immagine 1 di 2 Asus Eee PC 1005PEB RAM Replacement: passo 3, immagine 2 di 2
    • Identify the pins on both sides of the RAM.
    • Using both hands, pull the pins apart from each other to release the RAM.
    • The RAM will "pop" up on its own after the pins are pressed.
  4. Asus Eee PC 1005PEB RAM Replacement: passo 4, immagine 1 di 1
    • Grab the RAM stick with two fingers and gently pull it out of its slot.
Conclusione
Aaron Arenas
Membro da: 04/20/14
751 Reputazione
5 Guide realizzate
Cal Poly, Team 13-32, Maness Spring 2014 Membro di Cal Poly, Team 13-32, Maness Spring 2014
CPSU-MANESS-S14S13G32
5 Membri
5 Guide realizzate
Un commento
Everything I've read says you can only upgrade from the 1gb ram to a 2gig. Here's what I just installed: http://amzn.to/2x0flty and so far its working great...I notice a difference in speed, although this thing is still slow.
Dan Fowler - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 929
