Introduzione
The hard drive is located under the keyboard of the laptop. Before starting the guide, make sure the laptop's charger is not plugged in. Replacing the hard drive will require you to reinstall Windows on the laptop, so consider backing up your files before using the guide.
Warning: This guide causes warranty of laptop to be voided.
Cosa ti serve
Start by placing the laptop upside-down on a flat surface.
Find the two clips on the back portion of the laptop.
Face the laptop so the 4 silver "clips" along the middle of the battery cartridge are in front of you.
Turn the laptop right side up and lift the lid.
Insert the flat end of the spudger into the small gap between the top of the keyboard and the plastic of the laptop.
Using the spudger as leverage, lift the keyboard up from the rest of the laptop.
Run the spudger across the seam until the entire top edge is exposed. The two sides of the keyboard should also pop up in this process.
Using the pointed end of the spudger tool, disconnect the ribbon cable that extends from the bottom of the keyboard to the computer by pushing on the connections of the cable.
Once the ribbon cable is disconnected, the keyboard can be fully removed by lifting it away from the laptop.
Turn the laptop upside-down.
Find and unscrew the 6.65 mm Phillips #1 screw on the ram cover.
Altre 12 persone hanno completato questa guida.
Un commento
When I did this one, I was not careful enough with the keyboard removal, somehow causing the trackpad to stop working. Still, keyboard worked, so just used an external mouse and had a nice SSD.
