Salta al contenuto principale
Asus Eee PC 1005HA Screen Replacement
Cosa ti serve
  1. Asus Eee PC 1005HA Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Screen Replacement: passo 2, immagine 1 di 3 Asus Eee PC 1005HA Screen Replacement: passo 2, immagine 2 di 3 Asus Eee PC 1005HA Screen Replacement: passo 2, immagine 3 di 3
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Screen Replacement, Screen: passo 3, immagine 1 di 3 Asus Eee PC 1005HA Screen Replacement, Screen: passo 3, immagine 2 di 3 Asus Eee PC 1005HA Screen Replacement, Screen: passo 3, immagine 3 di 3
    • Using tweezers, remove the six screw covers on the screen bezel.
    • Remove the six 4.6 mm screws from the bezel.
  4. Asus Eee PC 1005HA Screen Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to disengage the plastic clips that secure the screen bezel to the display.
    • Carefully remove the bezel from the display.
  5. Asus Eee PC 1005HA Screen Replacement: passo 5, immagine 1 di 3 Asus Eee PC 1005HA Screen Replacement: passo 5, immagine 2 di 3 Asus Eee PC 1005HA Screen Replacement: passo 5, immagine 3 di 3
    • Remove the four 3.6 mm screws securing the screen.
    • Slowly lift the screen up from the rest of the laptop.
    • The screen is still attached to the laptop by a set of cables. Be careful not to damage them while removing the screen.
  6. Asus Eee PC 1005HA Screen Replacement: passo 6, immagine 1 di 2 Asus Eee PC 1005HA Screen Replacement: passo 6, immagine 2 di 2
    • Remove the plastic tape securing the display cables to the back of the screen.
    • Slide the display cable connector out its socket on the back of the screen.
  7. Asus Eee PC 1005HA Screen Replacement: passo 7, immagine 1 di 2 Asus Eee PC 1005HA Screen Replacement: passo 7, immagine 2 di 2
    • Remove the four 3.1 mm housing screws on the sides of the display housing frame
    • Remove the housing frame.
Conclusione
Altre 13 persone hanno completato questa guida.
Cal Poly, Team 11-22, Maness Winter 2012 Membro di Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 41
Tutti i Tempi: 20,827
