Salta al contenuto principale
Introduzione
Use this guide to replace or upgrade RAM in the Asus Eee PC 1005HA.
  1. Loosen the captive screw in the RAM compartment cover. Remove the RAM compartment cover. This photo shows the battery still attached, but it should be removed prior to removing or replacing the RAM.
    • Loosen the captive screw in the RAM compartment cover.
    • Remove the RAM compartment cover.
    • This photo shows the battery still attached, but it should be removed prior to removing or replacing the RAM.
  2. Pull the two RAM retaining arms away from the center of the RAM chip. Gently pull the RAM chip out of its socket. Gently pull the RAM chip out of its socket.
    • Pull the two RAM retaining arms away from the center of the RAM chip.
    • Gently pull the RAM chip out of its socket.
Conclusione
Altre 7 persone hanno completato questa guida.
Mitchell Cesare
Membro da: 31/01/2012
743 Reputazione
4 Guide realizzate
Cal Poly, Team 11-22, Maness Winter 2012 Membro di Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
3 Membri
12 Guide realizzate
Great guides. What is the maximum amount of RAM that this unit can accept?
MalikDon777 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 29
Tutti i Tempi: 10,075
