Salta al contenuto principale
Asus Eee PC 1000HA Hard Drive Replacement
Cosa ti serve
  1. Asus Eee PC 1000HA Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Remove the battery before working on your device. See this LINK for a step-by-step guide.
    • Gently turn the laptop up side down so that the battery is facing away from you. The battery is outlined by the red rectangle in the picture to the left.
  2. Asus Eee PC 1000HA Hard Drive Replacement: passo 2, immagine 1 di 2 Asus Eee PC 1000HA Hard Drive Replacement: passo 2, immagine 2 di 2
    • Use a #00 Phillips Head screw driver to remove the two 1/4" screws that hold the back panel in place.
  3. Asus Eee PC 1000HA Hard Drive Replacement: passo 3, immagine 1 di 1
    • Place the blue plastic 1/4" opening tool into the small indention and gently pry the back panel off.
  4. Asus Eee PC 1000HA Hard Drive Replacement: passo 4, immagine 1 di 1
    • Remove the back panel.
    • The hard drive is shown by the orange marker.
  5. Asus Eee PC 1000HA Hard Drive Replacement: passo 5, immagine 1 di 2 Asus Eee PC 1000HA Hard Drive Replacement: passo 5, immagine 2 di 2
    • Use the same, #00 Phillips Head screw driver to remove two 1/8" screws.
  6. Asus Eee PC 1000HA Hard Drive Replacement: passo 6, immagine 1 di 2 Asus Eee PC 1000HA Hard Drive Replacement: passo 6, immagine 2 di 2
    • To remove the hard drive, slide it to the right.
  7. Asus Eee PC 1000HA Hard Drive Replacement: passo 7, immagine 1 di 1
    • Grab the black tab and lift up to remove the hard drive from the computer.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,220
