Salta al contenuto principale
Asus EEE PC 1000HD Keyboard Replacement
Cosa ti serve
  1. Asus EEE PC 1000HD Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Note: Prior to changing the keyboard on your laptop, be sure to have a replacement keyboard on hand.
  2. Asus EEE PC 1000HD Keyboard Replacement: passo 2, immagine 1 di 2 Asus EEE PC 1000HD Keyboard Replacement: passo 2, immagine 2 di 2
    • Use a metal spudger and carefully insert the end of the flat tip into the edge of the keyboard.
    • Hold one end of the keyboard down to make prying easier.
    • Gently lift the metal spudger until you begin hearing clicking noises; these are the sounds of the keyboard unclasping from the board below.
  3. Asus EEE PC 1000HD Keyboard Replacement: passo 3, immagine 1 di 1
    • Once you lift the keyboard, there will be a metal tab that connects the keyboard to the metal panel below.
    • Detach this metal tab slowly.
  4. Asus EEE PC 1000HD Keyboard Replacement: passo 4, immagine 1 di 1
    • The keyboard should be fully detached.
    • With your new replacement keyboard, insert the metal tab back into the metal panel. Press gently on the keyboard to lock it into place.
    • There should be a few clicking noises as the new keyboard latches onto the metal board.
Conclusione
Emily Gao
Membro da: 10/17/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 551
