Salta al contenuto principale
Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement
  1. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement, Keyboard & Touchpad Assembly: passo 1, immagine 1 di 1
    • Remove the ten 5 mm silver screws on the back panel.
    • Remove the back panel.
  2. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the black wire connected to the audio card.
    • Remove the white wire connected to the audio card.
  3. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: passo 3, immagine 1 di 1
    • Remove the four 2.54 mm black screws connected to the battery and the speakers.
    • Take the battery out of the laptop
  4. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: passo 4, immagine 1 di 1
    • Remove the black strips that connect to the display.
  5. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: passo 5, immagine 1 di 1
    • Pry open the white gate, then disconnect the blue strip.
  6. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: passo 6, immagine 1 di 1
    • Pry open the black gate and then disconnect the blue strip.
  7. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: passo 7, immagine 1 di 1
    • Pry open the black gate, then disconnect the brown strip.
  8. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: passo 8, immagine 1 di 1
    • Remove the two silver screws located in the middle of the motherboard that hold down the copper heatsink.
    • Remove the heatsink from the motherboard.
  9. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: passo 9, immagine 1 di 1
    • Remove the eleven 2.5 mm screws from motherboard/daughterboard.
    • Remove the four 1.3 mm silver screws from the bottom of mother/daughterboard.
    • Remove the motherboard and daughterboard.
  10. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: passo 10, immagine 1 di 1
    • Remove the six 2.5 mm black display screws.
  11. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: passo 11, immagine 1 di 1
    • Remove the two 2.5 mm screws that secure the speakers.
    • Remove the speakers.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 247
