Salta al contenuto principale
Asus Chromebook Flip C100P Heatsink Replacement
Cosa ti serve
  1. Asus Chromebook Flip C100P Heatsink Replacement, Motherboard: passo 1, immagine 1 di 1
    • Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
  2. Asus Chromebook Flip C100P Heatsink Replacement: passo 2, immagine 1 di 1
    • Remove the five screws from beneath the rubber feet using a Phillips #0 screwdriver.
    • The first 1.9mm screw is located under the front right foot, the second 1.9mm screw and third 2.3mm screw are located under the rear right foot, and the fourth and fifth 2.3mm screws are located under the rear left foot.
  3. Asus Chromebook Flip C100P Heatsink Replacement: passo 3, immagine 1 di 1
    • Remove the nine bottom cover screws using a T5 screwdriver. Set apart the 6mm screw in the rear middle of the bottom cover from the the other eight 3mm screws, as it is longer than them.
    • Set apart the 6mm screw in the rear middle of the bottom cover from the the other eight 3mm screws, as it is longer than them
  4. Asus Chromebook Flip C100P Heatsink Replacement: passo 4, immagine 1 di 3 Asus Chromebook Flip C100P Heatsink Replacement: passo 4, immagine 2 di 3 Asus Chromebook Flip C100P Heatsink Replacement: passo 4, immagine 3 di 3
    • Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require extra power. Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
  5. Asus Chromebook Flip C100P Heatsink Replacement: passo 5, immagine 1 di 3 Asus Chromebook Flip C100P Heatsink Replacement: passo 5, immagine 2 di 3 Asus Chromebook Flip C100P Heatsink Replacement: passo 5, immagine 3 di 3
    • Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
  6. Asus Chromebook Flip C100P Heatsink Replacement: passo 6, immagine 1 di 3 Asus Chromebook Flip C100P Heatsink Replacement: passo 6, immagine 2 di 3 Asus Chromebook Flip C100P Heatsink Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the DC jack cable and the battery cable from the motherboard using tweezers, the pointed end of a plastic spudger, or by simply pulling the cables apart from the motherboard with your fingers.
  7. Asus Chromebook Flip C100P Heatsink Replacement: passo 7, immagine 1 di 2 Asus Chromebook Flip C100P Heatsink Replacement: passo 7, immagine 2 di 2
    • Disconnect the LCD cable from the motherboard using the pointed end of a plastic spudger.
  8. Asus Chromebook Flip C100P Heatsink Replacement: passo 8, immagine 1 di 2 Asus Chromebook Flip C100P Heatsink Replacement: passo 8, immagine 2 di 2
    • Disconnect the motherboard to powerboard cable from the motherboard using the pointed end of a plastic spudger.
  9. Asus Chromebook Flip C100P Heatsink Replacement: passo 9, immagine 1 di 2 Asus Chromebook Flip C100P Heatsink Replacement: passo 9, immagine 2 di 2
    • Disconnect the digitizer board cable from the motherboard using the pointed end of a plastic spudger.
  10. Asus Chromebook Flip C100P Heatsink Replacement: passo 10, immagine 1 di 1
    • Disconnect the two WiFi antenna cables from the motherboard using the pointed end of a plastic spudger or simply by pulling the cables apart from the motherboard with your fingers.
  11. Asus Chromebook Flip C100P Heatsink Replacement: passo 11, immagine 1 di 2 Asus Chromebook Flip C100P Heatsink Replacement: passo 11, immagine 2 di 2
    • Disconnect the speaker cable from the motherboard using the pointed end of a plastic spudger.
  12. Asus Chromebook Flip C100P Heatsink Replacement: passo 12, immagine 1 di 3 Asus Chromebook Flip C100P Heatsink Replacement: passo 12, immagine 2 di 3 Asus Chromebook Flip C100P Heatsink Replacement: passo 12, immagine 3 di 3
    • Remove the four 4.2mm speaker screws, then remove the two speakers using a philips head screwdriver.
  13. Asus Chromebook Flip C100P Heatsink Replacement: passo 13, immagine 1 di 2 Asus Chromebook Flip C100P Heatsink Replacement: passo 13, immagine 2 di 2
    • Remove the five 2.7mm motherboard screws with a T5 screwdriver.
  14. Asus Chromebook Flip C100P Heatsink Replacement: passo 14, immagine 1 di 1
    • Remove the motherboard.
  15. Asus Chromebook Flip C100P Heatsink Replacement, Heatsink: passo 15, immagine 1 di 2 Asus Chromebook Flip C100P Heatsink Replacement, Heatsink: passo 15, immagine 2 di 2
    • Remove the two 2.7mm heat sink screws with a T5 screwdriver, then remove the heat sink from the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Justin Ogihara
Membro da: 09/18/17
27.656 Reputazione
52 Guide realizzate
EDU Team Membro di EDU Team
Staff
7 Membri
677 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 516
