Introduzione
These steps will help you in the replacement of the battery for an Asus Chromebook Flip C100P. Either the battery has lost its ability to hold a charge, which in turn means you most likely have a dead battery that needs to be replaced. Before beginning, make sure to power off your device completely and disconnect the device from any external power source. '''A punctured battery can cause a dangerous fire. If your battery is swollen, take the appropriate precautions in this link: ++What to do with a swollen battery '''
Cosa ti serve
Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
To reassemble your device and complete the battery replacement, please follow these instructions in reverse order.
Altre 12 persone hanno completato questa guida.
Un commento
The difficulty rating should be higher. The sound card does not need to be removed, but this is not mentioned. I only noticed it from the next picture. Reattaching the keyboard cable is very difficult; a hint with tips would help.
