Salta al contenuto principale
Asus Chromebook C523N Touchpad Replacement
Cosa ti serve
  1. Asus Chromebook C523N Touchpad Replacement, Back Cover: passo 1, immagine 1 di 2 Asus Chromebook C523N Touchpad Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Touchpad Replacement: passo 2, immagine 1 di 2 Asus Chromebook C523N Touchpad Replacement: passo 2, immagine 2 di 2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Touchpad Replacement: passo 3, immagine 1 di 2 Asus Chromebook C523N Touchpad Replacement: passo 3, immagine 2 di 2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Touchpad Replacement, Battery: passo 4, immagine 1 di 3 Asus Chromebook C523N Touchpad Replacement, Battery: passo 4, immagine 2 di 3 Asus Chromebook C523N Touchpad Replacement, Battery: passo 4, immagine 3 di 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Gently disconnect the battery cable from the motherboard.
  5. Asus Chromebook C523N Touchpad Replacement: passo 5, immagine 1 di 2 Asus Chromebook C523N Touchpad Replacement: passo 5, immagine 2 di 2
    • Remove six 1.4 mm JIS #00 screws from the battery.
  6. Asus Chromebook C523N Touchpad Replacement: passo 6, immagine 1 di 1
    • Remove the battery from the laptop.
  7. Asus Chromebook C523N Touchpad Replacement, Touchpad: passo 7, immagine 1 di 1
    • Pull gently on the touchpad cable connector to disconnect.
  8. Asus Chromebook C523N Touchpad Replacement: passo 8, immagine 1 di 1
    • Carefully, remove the tape from the touch pad only.
  9. Asus Chromebook C523N Touchpad Replacement: passo 9, immagine 1 di 1
    • Remove the three 1.4 mm JIS #00 screws.
  10. Asus Chromebook C523N Touchpad Replacement: passo 10, immagine 1 di 2 Asus Chromebook C523N Touchpad Replacement: passo 10, immagine 2 di 2
    • Lift at the far edge of the touchpad to remove it.
Conclusione
Altre 2 persone hanno completato questa guida.
3Commenti sulla guida
Where do i buy the replacement touch pad
Anthony hughs - Replica
Very precise and clear. Thank you.
Raymond Trail - Replica
very clear instructions and photos. It was Easy, as described! One repairer had advised I buy a new Chromebook, bought an unused touchpad for £11. It took me a bit longer than the estimated 15 minutes, but this was the first time I’ve ever had the back off a laptop and attempted a repair/replacement, so took loads of photo’s on the way and took my time. I’ll definitely consider another DIY repair in the future.
John Outhwaite - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 26
Tutti i Tempi: 956
