Salta al contenuto principale
Asus Chromebook C523N Speaker Replacement
Cosa ti serve
  1. Asus Chromebook C523N Speaker Replacement, Back Cover: passo 1, immagine 1 di 2 Asus Chromebook C523N Speaker Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Speaker Replacement: passo 2, immagine 1 di 2 Asus Chromebook C523N Speaker Replacement: passo 2, immagine 2 di 2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Speaker Replacement: passo 3, immagine 1 di 2 Asus Chromebook C523N Speaker Replacement: passo 3, immagine 2 di 2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Speaker Replacement, Speaker: passo 4, immagine 1 di 3 Asus Chromebook C523N Speaker Replacement, Speaker: passo 4, immagine 2 di 3 Asus Chromebook C523N Speaker Replacement, Speaker: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Using the nylon tipped tweezers, gently pry the black and white wires from the wireless card and lift.
  5. Asus Chromebook C523N Speaker Replacement: passo 5, immagine 1 di 3 Asus Chromebook C523N Speaker Replacement: passo 5, immagine 2 di 3 Asus Chromebook C523N Speaker Replacement: passo 5, immagine 3 di 3
    • Use a spudger to pry the small tangle of black, red, white, and blue wires from the audio connector, pushing the wires back toward the speaker.
  6. Asus Chromebook C523N Speaker Replacement: passo 6, immagine 1 di 2 Asus Chromebook C523N Speaker Replacement: passo 6, immagine 2 di 2
    • Use a spudger to pry the black wire from the audio connector, pushing the wires back toward the left speaker.
  7. Asus Chromebook C523N Speaker Replacement: passo 7, immagine 1 di 1
    • Gently grab both speakers and lift them from the Chromebook to remove.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 13
Tutti i Tempi: 677
