Salta al contenuto principale
Asus Chromebook C300SA-DS02 VECO Speakers Replacement
Cosa ti serve
  1. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, Keyboard: passo 1, immagine 1 di 2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, Keyboard: passo 1, immagine 2 di 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 2, immagine 1 di 3 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 2, immagine 2 di 3 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 2, immagine 3 di 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 3, immagine 1 di 3 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 3, immagine 2 di 3 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 3, immagine 3 di 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 4, immagine 1 di 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, Battery: passo 5, immagine 1 di 2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 6, immagine 1 di 2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 6, immagine 2 di 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 7, immagine 1 di 1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, VECO Speakers: passo 8, immagine 1 di 1
    • Unplug the speaker cable from the motherboard.
  9. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 9, immagine 1 di 2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 9, immagine 2 di 2
    • Start by removing the right speaker first.
    • There are two metal clips and one plastic clip holding the right speaker in place. Push them back and lift speaker out of the laptop.
    • Use a screwdriver to gently push back the metal clips.
  10. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 10, immagine 1 di 2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 10, immagine 2 di 2
    • Untangle the wire connecting the right speaker to the left speaker.
    • Move right speaker and wires away from your working space.
    • Do not lift wire straight up, there are five interlocking ribs holding this wire in place.
  11. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 11, immagine 1 di 1
    • You can use a screwdriver to push back the clips if needed.
  12. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: passo 12, immagine 1 di 1
    • Lift speakers and cable away from the laptop.
Conclusione
Sam LaBelle
Membro da: 10/17/17
107 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 361
