Salta al contenuto principale
Asus Chromebook C300SA-DS02 Trackpad Replacement
Cosa ti serve
  1. Asus Chromebook C300SA-DS02 Trackpad Replacement, Keyboard: passo 1, immagine 1 di 2 Asus Chromebook C300SA-DS02 Trackpad Replacement, Keyboard: passo 1, immagine 2 di 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 2, immagine 1 di 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 2, immagine 2 di 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 2, immagine 3 di 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 3, immagine 1 di 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 3, immagine 2 di 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 3, immagine 3 di 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 4, immagine 1 di 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 Trackpad Replacement, Trackpad: passo 5, immagine 1 di 2 Asus Chromebook C300SA-DS02 Trackpad Replacement, Trackpad: passo 5, immagine 2 di 2
    • Flip over the keyboard assembly to reveal the trackpad beneath.
  6. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 6, immagine 1 di 2 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 6, immagine 2 di 2
    • Peel up the two pieces of foil tape holding down the trackpad.
  7. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 7, immagine 1 di 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 7, immagine 2 di 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 7, immagine 3 di 3
    • Use a spudger to release the locking bar of the ZIF connector near the center of the trackpad.
    • Slide the cable ribbon from the connector.
  8. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 8, immagine 1 di 1
    • Peel back the ribbon cable, which is adhered to the trackpad.
  9. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 9, immagine 1 di 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 9, immagine 2 di 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 9, immagine 3 di 3
    • Remove the four 2.5mm Phillips #0 screws along the top edge of the trackpad.
  10. Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 10, immagine 1 di 2 Asus Chromebook C300SA-DS02 Trackpad Replacement: passo 10, immagine 2 di 2
    • Pry the trackpad from the top edge with a finger or spudger.
    • Lift the trackpad up and away from the keyboard assembly.
Conclusione
Austin Blakely
Membro da: 03/11/19
19.506 Reputazione
53 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 179
