Salta al contenuto principale
Asus Chromebook C300SA-DS02 Motherboard Replacement
Cosa ti serve
  1. Asus Chromebook C300SA-DS02 Motherboard Replacement, Keyboard: passo 1, immagine 1 di 2 Asus Chromebook C300SA-DS02 Motherboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 2, immagine 1 di 3 Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 2, immagine 2 di 3 Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 2, immagine 3 di 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 3, immagine 1 di 3 Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 3, immagine 2 di 3 Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 3, immagine 3 di 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 Motherboard Replacement, Battery: passo 5, immagine 1 di 2 Asus Chromebook C300SA-DS02 Motherboard Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 6, immagine 1 di 2 Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 6, immagine 2 di 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 7, immagine 1 di 1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 Motherboard Replacement, Display Assembly: passo 8, immagine 1 di 2 Asus Chromebook C300SA-DS02 Motherboard Replacement, Display Assembly: passo 8, immagine 2 di 2
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 9, immagine 1 di 1
    • Peel back the tape covering the display cable.
    • Ease the cable towards the screen and out from the connector.
  10. Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 10, immagine 1 di 1
    • Use a Phillips #0 driver to remove the six 5mm screws on the top right and left display hinges.
  11. Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 11, immagine 1 di 1
    • Gently lift the display assembly up and away from the laptop.
  12. Asus Chromebook C300SA-DS02 Motherboard Replacement, WiFi Card: passo 12, immagine 1 di 3 Asus Chromebook C300SA-DS02 Motherboard Replacement, WiFi Card: passo 12, immagine 2 di 3 Asus Chromebook C300SA-DS02 Motherboard Replacement, WiFi Card: passo 12, immagine 3 di 3
    • Use the spudger to pop the black and white coaxial WiFi cables up from the WiFi card.
  13. Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 13, immagine 1 di 2 Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 13, immagine 2 di 2
    • Remove the one 3.6mm Phillips #0 screw from the WiFi card.
    • Pull and lift the WiFi card away from the motherboard.
  14. Asus Chromebook C300SA-DS02 Motherboard Replacement, Motherboard: passo 14, immagine 1 di 3 Asus Chromebook C300SA-DS02 Motherboard Replacement, Motherboard: passo 14, immagine 2 di 3 Asus Chromebook C300SA-DS02 Motherboard Replacement, Motherboard: passo 14, immagine 3 di 3
    • Using your Phillips #0 screwdriver, unscrew three, 3.6mm screws from the silver heatsink.
    • Remove the heatsink from the motherboard.
  15. Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 15, immagine 1 di 2 Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 15, immagine 2 di 2
    • Remove the black tape from the motherboard covering the 4.2mm silver flat screw.
    • Using a Phillips #0 screwdriver, remove the 4.4mm screw on the right and the 4.2mm silver flat screw on the left from the motherboard.
    • This is a used device so the screws may be different than the original Chromebook.
  16. Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 16, immagine 1 di 3 Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 16, immagine 2 di 3 Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 16, immagine 3 di 3
    • Using the black nylon spudger, unlock the black bar on the ZIF connector attached to the mid-right of the motherboard.
    • Remove the ribbon cable that attaches the motherboard to the daughterboard.
  17. Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 17, immagine 1 di 2 Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 17, immagine 2 di 2
    • Using the black nylon spudger, carefully slide the speaker cable connector out from its attachment on the motherboard.
  18. Asus Chromebook C300SA-DS02 Motherboard Replacement: passo 18, immagine 1 di 1
    • Wiggle and pull the motherboard out from the bottom case.
Conclusione
Sarah Westberg
Membro da: 03/11/19
22.717 Reputazione
70 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
16.573 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 356
