Salta al contenuto principale
Asus Chromebook C300SA-DS02 LED Screen Replacement
Cosa ti serve
  1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: passo 1, immagine 1 di 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: passo 1, immagine 2 di 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 2, immagine 1 di 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 2, immagine 2 di 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 2, immagine 3 di 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 3, immagine 1 di 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 3, immagine 2 di 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 3, immagine 3 di 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 4, immagine 1 di 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: passo 5, immagine 1 di 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 6, immagine 1 di 2 Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 6, immagine 2 di 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 7, immagine 1 di 1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: passo 8, immagine 1 di 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: passo 8, immagine 2 di 2
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 9, immagine 1 di 1
    • Peel back the tape covering the plug.
    • Slide the cable towards the screen and out of the input.
  10. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 10, immagine 1 di 1
    • Unscrew the 6 screws (5 millimeter) on the top right and left.
  11. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 11, immagine 1 di 1
    • Gently lift the screen up and away from the laptop.
  12. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 12, immagine 1 di 1
    • Pry off the face panel on the screen using the blue prying tool.
  13. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 13, immagine 1 di 1
    • Remove the four 2mm Phillips #0 screws from the four corners of the screen.
  14. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 14, immagine 1 di 2 Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 14, immagine 2 di 2
    • Gently lift screen
    • Peel back the adhesive covering the cable.
    • Remove the cable to free the screen.
Conclusione
Un commento
I used this honestly I broke the screen and some of the wires in the screen are severed. Now I know for sure where the wires go and how to deconstruct it. Thank you so much!
Glorybringers Child - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 710
