Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide will walk you through the step by step process of removing the display assembly from the laptop. To replace just the LED screen component within rather than the entire assembly, refer to Asus Chromebook C300SA-DS02 Screen Replacement.
  1. Power the laptop off and make sure the charger is unplugged before starting. Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Open the laptop. Using an iFixit opening tool, pry along the edges of the keyboard. Lift the keyboard and slide it gently towards you.
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable. Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable. Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Remove the keyboard from the laptop.
    • Remove the keyboard from the laptop.
  5. Remove the six 5.6mm Phillips #0 screws around the battery. Remove the six 5.6mm Phillips #0 screws around the battery.
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard. Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Lift the battery out of the laptop.
    • Lift the battery out of the laptop.
  8. Unplug the black and white cable from the motherboard. These two wires connect to the antenna within the display assembly.  The white cable is longer and connects to the bottom import.
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Peel back the tape covering the display cable.
    • Peel back the tape covering the display cable.
    • Ease the cable towards the screen and out from the connector.
  10. Use a Phillips #0 driver to remove the six 5mm screws on the top right and left display hinges.
    • Use a Phillips #0 driver to remove the six 5mm screws on the top right and left display hinges.
  11. Gently lift the display assembly up and away from the laptop.
    • Gently lift the display assembly up and away from the laptop.
Conclusione
Celina Monteiro
Membro da: 17/10/2017
224 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 79
