Salta al contenuto principale
Asus Chromebook C300SA- DS02 Battery Replacement
Cosa ti serve
  1. Asus Chromebook C300SA- DS02 Battery Replacement, Keyboard: passo 1, immagine 1 di 2 Asus Chromebook C300SA- DS02 Battery Replacement, Keyboard: passo 1, immagine 2 di 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA- DS02 Battery Replacement: passo 2, immagine 1 di 3 Asus Chromebook C300SA- DS02 Battery Replacement: passo 2, immagine 2 di 3 Asus Chromebook C300SA- DS02 Battery Replacement: passo 2, immagine 3 di 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA- DS02 Battery Replacement: passo 3, immagine 1 di 3 Asus Chromebook C300SA- DS02 Battery Replacement: passo 3, immagine 2 di 3 Asus Chromebook C300SA- DS02 Battery Replacement: passo 3, immagine 3 di 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA- DS02 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA- DS02 Battery Replacement, Battery: passo 5, immagine 1 di 2 Asus Chromebook C300SA- DS02 Battery Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA- DS02 Battery Replacement: passo 6, immagine 1 di 2 Asus Chromebook C300SA- DS02 Battery Replacement: passo 6, immagine 2 di 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA- DS02 Battery Replacement: passo 7, immagine 1 di 1
    • Lift the battery out of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 970
