Salta al contenuto principale
Asus Chromebook C300MA-EDU Keyboard Replacement
Cosa ti serve
  1. Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Keyboard Replacement: passo 2, immagine 1 di 2 Asus Chromebook C300MA-EDU Keyboard Replacement: passo 2, immagine 2 di 2
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Keyboard Replacement: passo 3, immagine 1 di 3 Asus Chromebook C300MA-EDU Keyboard Replacement: passo 3, immagine 2 di 3 Asus Chromebook C300MA-EDU Keyboard Replacement: passo 3, immagine 3 di 3
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
Conclusione
USF Tampa, Team S2-G3, Nance Fall 2017 Membro di USF Tampa, Team S2-G3, Nance Fall 2017
USFT-NANCE-F17S2G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 692
