Salta al contenuto principale
Asus Chromebook C300MA-DH02 Wireless Card Replacement
Cosa ti serve
  1. Asus Chromebook C300MA-DH02 Wireless Card Replacement, Keyboard Panel: passo 1, immagine 1 di 3 Asus Chromebook C300MA-DH02 Wireless Card Replacement, Keyboard Panel: passo 1, immagine 2 di 3 Asus Chromebook C300MA-DH02 Wireless Card Replacement, Keyboard Panel: passo 1, immagine 3 di 3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Wireless Card Replacement: passo 2, immagine 1 di 1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Wireless Card Replacement: passo 3, immagine 1 di 2 Asus Chromebook C300MA-DH02 Wireless Card Replacement: passo 3, immagine 2 di 2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 1
    • Using the Phillips #000 screwdriver, unscrew the 4mm screw.
  5. Asus Chromebook C300MA-DH02 Wireless Card Replacement: passo 5, immagine 1 di 1
    • Gently remove the wireless card making sure to not damage the connecting port.
Conclusione
USF Tampa, Team S6-G4, Remmell Fall 2017 Membro di USF Tampa, Team S6-G4, Remmell Fall 2017
USFT-REMMELL-F17S6G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 143
