Salta al contenuto principale
Asus Chromebook C300MA-DH02 Display Replacement
Cosa ti serve
  1. Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: passo 1, immagine 1 di 3 Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: passo 1, immagine 2 di 3 Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: passo 1, immagine 3 di 3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Display Replacement: passo 2, immagine 1 di 1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Display Replacement: passo 3, immagine 1 di 2 Asus Chromebook C300MA-DH02 Display Replacement: passo 3, immagine 2 di 2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Display Replacement, Display: passo 4, immagine 1 di 2 Asus Chromebook C300MA-DH02 Display Replacement, Display: passo 4, immagine 2 di 2
    • Remove the hinge protector by using the plastic opening tool to gently lift it up. It should come up easily.
  5. Asus Chromebook C300MA-DH02 Display Replacement: passo 5, immagine 1 di 2 Asus Chromebook C300MA-DH02 Display Replacement: passo 5, immagine 2 di 2
    • Using the plastic opening tool, separate the display cover bracket from the back of the display. Start from the top.
  6. Asus Chromebook C300MA-DH02 Display Replacement: passo 6, immagine 1 di 2 Asus Chromebook C300MA-DH02 Display Replacement: passo 6, immagine 2 di 2
    • Remove the (4) four "4mm" screws in each corner that hold the display using the Phillips #000 screwdriver.
  7. Asus Chromebook C300MA-DH02 Display Replacement: passo 7, immagine 1 di 1
    • Lower the display to allow access to connector in back.
  8. Asus Chromebook C300MA-DH02 Display Replacement: passo 8, immagine 1 di 2 Asus Chromebook C300MA-DH02 Display Replacement: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift the tape covering the connector with the tweezers.
    • Gently remove the display connector from the motherboard.
Conclusione
USF Tampa, Team S6-G4, Remmell Fall 2017 Membro di USF Tampa, Team S6-G4, Remmell Fall 2017
USFT-REMMELL-F17S6G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 237
