Salta al contenuto principale
Asus Chromebook C300MA-DB01 Screen Replacement
Cosa ti serve
  1. Asus Chromebook C300MA-DB01 Screen Replacement, Screen: passo 1, immagine 1 di 2 Asus Chromebook C300MA-DB01 Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Use plastic opening tool to remove the frame around the screen. It is recommended to start in the upper corners.
  2. Asus Chromebook C300MA-DB01 Screen Replacement: passo 2, immagine 1 di 2 Asus Chromebook C300MA-DB01 Screen Replacement: passo 2, immagine 2 di 2
    • Use plastic opening tool to remove plastic hinge casing located between the screen and keyboard.
  3. Asus Chromebook C300MA-DB01 Screen Replacement: passo 3, immagine 1 di 1
    • Use 64 bitdriver to remove 4 6.0 mm Phillips screws from screen the screws that need to be removed are located in the corners of the screen.
  4. Asus Chromebook C300MA-DB01 Screen Replacement: passo 4, immagine 1 di 1
    • Use plastic prying tool to detach the wire that connects the screen to the lower non-display half of the laptop.
  5. Asus Chromebook C300MA-DB01 Screen Replacement: passo 5, immagine 1 di 1
    • Lift and remove screen from the laptop.
Conclusione
wyatt boyatt
Membro da: 09/25/17
541 Reputazione
5 Guide realizzate
USF Tampa, Team S4-G3, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S4G3
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 351
