Salta al contenuto principale
Asus Chromebook C300MA-DB01 Keyboard Replacement
Cosa ti serve
  1. Asus Chromebook C300MA-DB01 Keyboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Keyboard Replacement: passo 3, immagine 1 di 1
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Keyboard Replacement: passo 4, immagine 1 di 2 Asus Chromebook C300MA-DB01 Keyboard Replacement: passo 4, immagine 2 di 2
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
  5. Asus Chromebook C300MA-DB01 Keyboard Replacement, Keyboard: passo 5, immagine 1 di 1
    • Use plastic opening tool to pry open clip holding keyboard wires to the circuitboard.
  6. Asus Chromebook C300MA-DB01 Keyboard Replacement: passo 6, immagine 1 di 1
    • Use plastic opening tool to pry open clip holding mouse pad wires to the circuit board.
    • Use plastic opening tool to pry open clip holding keyboard flat black wire
    • Use plastic opening tool to pry open clip holding keyboard thiner white wire
  7. Asus Chromebook C300MA-DB01 Keyboard Replacement: passo 7, immagine 1 di 1
    • Lift and remove keyboard from device.
Conclusione
wyatt boyatt
Membro da: 09/25/17
541 Reputazione
5 Guide realizzate
USF Tampa, Team S4-G3, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S4G3
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 316
