Salta al contenuto principale
Asus Chromebook C300MA-BBCLN12 Display Replacement
Cosa ti serve
  1. Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: passo 1, immagine 1 di 3 Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: passo 1, immagine 2 di 3 Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: passo 1, immagine 3 di 3
    • Wedge the tip of the plastic spudger between the outer display casing and the inner display panel liner.
    • Separate the outer display casing from the inner display panel by sliding the plastic spudger around the perimeter of the display.
    • It is necessary to pull the inner display panel firmly when separating it from the outer display casing along the bottom of the device.
  2. Asus Chromebook C300MA-BBCLN12 Display Replacement: passo 2, immagine 1 di 3 Asus Chromebook C300MA-BBCLN12 Display Replacement: passo 2, immagine 2 di 3 Asus Chromebook C300MA-BBCLN12 Display Replacement: passo 2, immagine 3 di 3
    • Remove the four 3.0mm PH00 screws from the four corners of the display.
    • Grip the edges of the display and tip it forward until it rests on the keyboard.
    • A cable connects the display to the display casing at the bottom. Separate the display panel slowly to prevent damaging the cable.
  3. Asus Chromebook C300MA-BBCLN12 Display Replacement: passo 3, immagine 1 di 3 Asus Chromebook C300MA-BBCLN12 Display Replacement: passo 3, immagine 2 di 3 Asus Chromebook C300MA-BBCLN12 Display Replacement: passo 3, immagine 3 di 3
    • Locate the gold cable connector that attaches the display to the bottom of the display housing.
    • Peel back the protective tape that covers the gold connector.
    • Disconnect the display from the display housing by gripping the sides of the gold display cable connector and pulling away from the bottom of the display.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 226
