Salta al contenuto principale
Asus Chromebook C300MA-BBCLN12 Battery Replacement
Cosa ti serve
  1. Asus Chromebook C300MA-BBCLN12 Battery Replacement, Battery: passo 1, immagine 1 di 2 Asus Chromebook C300MA-BBCLN12 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the eight 9.0mm Phillips #00 screws.
    • Remove the three 6.0mm Phillips #00 screws.
  2. Asus Chromebook C300MA-BBCLN12 Battery Replacement: passo 2, immagine 1 di 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: passo 2, immagine 2 di 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: passo 2, immagine 3 di 3
    • Separate the palm rest assembly from the bottom housing using the plastic opening tool.
    • It is recommended that you start from a corner and run the plastic opening tool along the edge of the housing.
    • Lift the palm rest assembly slowly to prevent damaging the two cables that connect it to the motherboard.
  3. Asus Chromebook C300MA-BBCLN12 Battery Replacement: passo 3, immagine 1 di 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: passo 3, immagine 2 di 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
    • Disconnect the wide black cable from the motherboard by pulling the blue cable tab away from the connector.
    • Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab away from the connector.
  4. Asus Chromebook C300MA-BBCLN12 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the six 6.0mm Phillips #00 screws that secure the battery to the bottom housing.
  5. Asus Chromebook C300MA-BBCLN12 Battery Replacement: passo 5, immagine 1 di 2 Asus Chromebook C300MA-BBCLN12 Battery Replacement: passo 5, immagine 2 di 2
    • Disconnect the bundled cable connector that attaches the battery to the motherboard using the small plastic spudger.
  6. Asus Chromebook C300MA-BBCLN12 Battery Replacement: passo 6, immagine 1 di 1
    • Remove the battery from the bottom housing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 16
Tutti i Tempi: 387
