Introduzione
This guide will show you how to open the casing on your Chromebook and remove your battery to replace it.
Cosa ti serve
Remove the eight 9.0mm Phillips #00 screws.
Remove the three 6.0mm Phillips #00 screws.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
Disconnect the wide black cable from the motherboard by pulling the blue cable tab away from the connector.
Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab away from the connector.
