Salta al contenuto principale
Asus Chromebook C300MA DB01 Battery Replacement
Cosa ti serve
  1. Asus Chromebook C300MA DB01 Battery Replacement, Removing the Back Cover: passo 1, immagine 1 di 1
    • Remove the eight 9.0 mm Phillips screws along the perimeter of the case.
    • Remove the three 6.0 mm Phillips screws from the center of the case.
  2. Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: passo 2, immagine 1 di 2 Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: passo 2, immagine 2 di 2
    • Slide the Jimmy in between the keyboard and underside of the laptop to remove the keyboard.
    • Leave the keyboard face down on the screen.
    • Do not pull the keyboard away from the laptop. The keyboard will still be attached with wires.
  3. Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: passo 3, immagine 1 di 2 Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: passo 3, immagine 2 di 2
    • Use a nylon spudger to lift the latch on each wire jack and detach the keyboard wires.
    • After the tabs have been lifted, the wire can be gently pulled out by hand.
    • Set the keyboard aside.
  4. Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: passo 4, immagine 1 di 3 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: passo 4, immagine 2 di 3 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: passo 4, immagine 3 di 3
    • Remove the six 6.0mm Phillips screws on the battery.
    • Remove the wire jack from the battery. Use a nylon spudger to lift the latch.
    • Remove the battery from the device.
Conclusione
Earl Gill IV
Membro da: 04/01/19
193 Reputazione
2 Guide realizzate
IUPUI, Team S10-G10, Wilson Spring 2019 Membro di IUPUI, Team S10-G10, Wilson Spring 2019
IUPUI-WILSON-S19S10G10
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 190
