Salta al contenuto principale
Asus Chromebook C300M USB Port Replacement
Cosa ti serve
  1. Asus Chromebook C300M USB Port Replacement, USB Port: passo 1, immagine 1 di 2 Asus Chromebook C300M USB Port Replacement, USB Port: passo 1, immagine 2 di 2
    • Flip the chromebook on its front.
    • Remove the screws on the back using the Phillips #1 screwdriver.
    • Remove the six 8mm screws.
    • Remove the five 5mm screws.
  2. Asus Chromebook C300M USB Port Replacement: passo 2, immagine 1 di 1
    • Separate the plastic case from the keyboard at the seam using a plastic opening tool.
  3. Asus Chromebook C300M USB Port Replacement: passo 3, immagine 1 di 2 Asus Chromebook C300M USB Port Replacement: passo 3, immagine 2 di 2
    • Fully separate the plastic case from the keyboard by lifting it upward.
  4. Asus Chromebook C300M USB Port Replacement: passo 4, immagine 1 di 2 Asus Chromebook C300M USB Port Replacement: passo 4, immagine 2 di 2
    • The small and wide ribbon cables connect the keyboard to the motherboard.
    • Disconnect the small ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
    • Disconnect the wide ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
  5. Asus Chromebook C300M USB Port Replacement: passo 5, immagine 1 di 2 Asus Chromebook C300M USB Port Replacement: passo 5, immagine 2 di 2
    • Disconnect the USB port in the top right corner from the motherboard.
    • Unplug the the wide ribbon cable using spudger.
  6. Asus Chromebook C300M USB Port Replacement: passo 6, immagine 1 di 2 Asus Chromebook C300M USB Port Replacement: passo 6, immagine 2 di 2
    • Remove the single 3mm screw on the left and bottom side of the USB Port using the Phillips #1 screwdriver.
    • Remove the three 5mm screws on the upper part of the USB port with the same screwdriver.
    • Lift the edge of the white casing. Remove the USB Port by pulling it toward the bottom of the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
Rachel Cadle
Membro da: 04/02/19
259 Reputazione
2 Guide realizzate
IUPUI, Team S3-G2, Harley Spring 2019 Membro di IUPUI, Team S3-G2, Harley Spring 2019
IUPUI-HARLEY-S19S3G2
3 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 815
