Salta al contenuto principale
Asus Chromebook C300M Mousepad Replacement
Cosa ti serve
  1. Asus Chromebook C300M Mousepad Replacement, Mousepad: passo 1, immagine 1 di 2 Asus Chromebook C300M Mousepad Replacement, Mousepad: passo 1, immagine 2 di 2
    • Flip the Chromebook on its front.
    • Remove the screws on the back using the Phillips #1 screwdriver.
    • Remove the six 8mm screws.
    • Remove the five 5mm screws.
  2. Asus Chromebook C300M Mousepad Replacement: passo 2, immagine 1 di 1
    • Separate the plastic case from the keyboard at the seam by using a plastic opening tool.
  3. Asus Chromebook C300M Mousepad Replacement: passo 3, immagine 1 di 3 Asus Chromebook C300M Mousepad Replacement: passo 3, immagine 2 di 3 Asus Chromebook C300M Mousepad Replacement: passo 3, immagine 3 di 3
    • The small and wide ribbon cables connect the keyboard to the motherboard.
    • Disconnect the small ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
    • Disconnect the wide ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using spudger.
  4. Asus Chromebook C300M Mousepad Replacement: passo 4, immagine 1 di 3 Asus Chromebook C300M Mousepad Replacement: passo 4, immagine 2 di 3 Asus Chromebook C300M Mousepad Replacement: passo 4, immagine 3 di 3
    • Remove the keyboard and flip it onto its front. You should see the back of the mousepad.
    • Lift the foil strips to reveal two hidden screws. Then remove all four 2mm screws from the top of the trackpad with the Phillips #1 screwdriver.
    • Remove the mousepad by sliding it upward.
Conclusione
Rachel Cadle
Membro da: 04/02/19
259 Reputazione
2 Guide realizzate
IUPUI, Team S3-G2, Harley Spring 2019 Membro di IUPUI, Team S3-G2, Harley Spring 2019
IUPUI-HARLEY-S19S3G2
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 303
