Salta al contenuto principale
Asus Chromebook C300M Key Replacement
Cosa ti serve
  1. Asus Chromebook C300M Key Replacement, Bottom Panel: passo 1, immagine 1 di 1
    • Flip the Chromebook over, bottom-side up.
  2. Asus Chromebook C300M Key Replacement: passo 2, immagine 1 di 2 Asus Chromebook C300M Key Replacement: passo 2, immagine 2 di 2
    • Remove the screws from the 11 spots using the aluminum driver with the J00 Philips head provided in iFixit toolkit.
    • Remove the eight 9.0mm Philips screws along the perimeter of the case.
    • Remove the three 6.0mm Philips screws from the center of the case.
    • Some versions may instead have six bigger screws (the four on the upper side of the image, close to the hinge, and two on the sides) and five smaller ones (four at the bottom of the image, where the laptop is thinner, and one in the center).
  3. Asus Chromebook C300M Key Replacement: passo 3, immagine 1 di 1
    • Using a plastic opening tool, work around the Chromebook separating the plastic case at the seam.
  4. Asus Chromebook C300M Key Replacement: passo 4, immagine 1 di 1
    • Open the Chromebook at hinges.
  5. Asus Chromebook C300M Key Replacement, Key: passo 5, immagine 1 di 1
    • Detach the wide black keyboard cable from the switchboard.
  6. Asus Chromebook C300M Key Replacement: passo 6, immagine 1 di 1
    • Unplug the white keyboard cable from switchboard.
  7. Asus Chromebook C300M Key Replacement: passo 7, immagine 1 di 1
    • Remove the keyboard from the laptop body.
  8. Asus Chromebook C300M Key Replacement: passo 8, immagine 1 di 1
    • Use the plastic opening tool to loosen a key of choice.
  9. Asus Chromebook C300M Key Replacement: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Removed the loosened key with the tweezers.
Conclusione
Altre 6 persone hanno completato questa guida.
Un commento
hello, i have a asus c300 my problem is when i open it i have get it just right to see picture .is it my video cable?
clint murchison - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 28
Tutti i Tempi: 5,204
