Introduzione
If the audio of your Asus Chromebook C213SA-YS02 is still non-functional after you have completed troubleshooting, it may be time to replace the speakers. After following the steps of replacing the battery, accessing the speakers should not be too much of a problem to handle.
Cosa ti serve
Power off the device by pressing and holding the power button on the side of the device.
Remove the power cable from the back of the device (if applicable).
Remove the seven black 4mm Phillips screws underneath the back cover.
Remove the eight black 7mm Phillips #00 screws along the edge of the device.
Remove the single silver 2mm Phillips #00 screw from the top of the Wi-Fi card.
Carefully pull the white and black wires out of the card using tweezers.
Remove the Wi-Fi card.
Disconnect the black camera cable between the keyboard cable and the two blue ribbons which have been disconnected.
Using the tweezers, grab the wire end of the cable and carefully pull it away from the connection port.
Loosely place the disconnected cable away from the connection port.
Flip the device over and open up the LCD screen.
Using the iFixit opening tool, gently place the tool in between the back-plate and the keyboard and lift up.
Slide the tool around the outside of the keyboard and lift up the tool while moving it around the boundary of the keyboard.
Pull the keyboard away from the back-plate. Be careful the keyboard cable is not caught on the back-plate while performing this maneuver.
Remove the battery cable from the connection port using the iFixit opening tool to push the white tabs on either end of the male adapter.
Remove the three 4mm Phillips #00 stainless steel screws.
Remove the battery.
Use the iFixit opening tool to pry up on the black speakers located on the side of the backplate.
Carefully pull the cable wire out of the back plate.
Repeat the first step to the speaker on the opposite side.
