Salta al contenuto principale
Asus Chromebook C202SA-YS02 Screen Replacement
Cosa ti serve
  1. Asus Chromebook C202SA-YS02 Screen Replacement, Bezel: passo 1, immagine 1 di 1
    • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
  2. Asus Chromebook C202SA-YS02 Screen Replacement: passo 2, immagine 1 di 1
    • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
  3. Asus Chromebook C202SA-YS02 Screen Replacement: passo 3, immagine 1 di 1
    • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
  4. Asus Chromebook C202SA-YS02 Screen Replacement, Screen: passo 4, immagine 1 di 3 Asus Chromebook C202SA-YS02 Screen Replacement, Screen: passo 4, immagine 2 di 3 Asus Chromebook C202SA-YS02 Screen Replacement, Screen: passo 4, immagine 3 di 3
    • Unscrew and remove the four screws holding the screen in place.
  5. Asus Chromebook C202SA-YS02 Screen Replacement: passo 5, immagine 1 di 1
    • Fold down screen and remove the screen connector band. You may have to use a small flat blade or a spudger, since the latch is very small.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 31
Tutti i Tempi: 3,407
