Salta al contenuto principale
Asus Chromebook C202SA-YS02 Palm Rest Replacement
Cosa ti serve
  1. Asus Chromebook C202SA-YS02 Palm Rest Replacement, Palm Rest: passo 1, immagine 1 di 1
    • Turn the device over so the bottom is facing up.
    • Remove the ten Phillips #1 8.0 mm screws.
  2. Asus Chromebook C202SA-YS02 Palm Rest Replacement: passo 2, immagine 1 di 2 Asus Chromebook C202SA-YS02 Palm Rest Replacement: passo 2, immagine 2 di 2
    • Carefully use the plastic opening tool to pry the palm rest apart from the bottom cover. Start from one spot and systematically work your way around until the whole palm rest is detached.
  3. Asus Chromebook C202SA-YS02 Palm Rest Replacement: passo 3, immagine 1 di 1
    • Disconnect the two cables that run from the keyboard to the motherboard and from the touch pad to the motherboard.
    • You may have to use a spudger to lift open the respective latches.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 19
Tutti i Tempi: 695
