Introduzione
The keyboard is an important part of the Asus C202 Chromebook. The keyboard is easy to replace requiring no special skill set. The keyboard will need to be replaced if keys are missing, if keys have progressively stopped working, or if the entire keyboard does not respond to user input. Replacing the keyboard is a delicate process—if you are not careful you could damage the motherboard. Before you replace the keyboards make certain to power off the device. Keep your work space clean as to not damage the exposed circuitry.
Cosa ti serve
Turn the device over so the bottom is facing up.
Remove the ten Phillips #1 8.0 mm screws.
Once the cables are disconnected, remove the keyboard from the back panel.
Now that the keyboard is disconnected, you can replace it with a new one.
Un commento
Is it easy if your replacement keyboard doesn't include the frame? How does the frame attach to the keyboard?
