Salta al contenuto principale
Asus Chromebook C201PA-DS02-LG Screen Replacement
Cosa ti serve
  1. Asus Chromebook C201PA-DS02-LG Screen Replacement, Keyboard: passo 1, immagine 1 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement, Keyboard: passo 1, immagine 2 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement, Keyboard: passo 1, immagine 3 di 3
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 2, immagine 1 di 2 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 3, immagine 1 di 2 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 4, immagine 1 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 4, immagine 2 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 4, immagine 3 di 3
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 5, immagine 1 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 5, immagine 2 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 5, immagine 3 di 3
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Screen Replacement, Metal Plate: passo 6, immagine 1 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement, Metal Plate: passo 6, immagine 2 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement, Metal Plate: passo 6, immagine 3 di 3
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Screen Replacement, Screen: passo 7, immagine 1 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement, Screen: passo 7, immagine 2 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement, Screen: passo 7, immagine 3 di 3
    • Unscrew the 4mm screws with a Phillips #0 screwdriver by rotating the screwdriver counterclockwise.
    • There is a screw that is hidden under the black tarped connection that connects the screen to the motherboard.
  8. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 8, immagine 1 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 8, immagine 2 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift the tarp material straight up off the external output using tweezers. It is simply taped on.
  9. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 9, immagine 1 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 9, immagine 2 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 9, immagine 3 di 3
    • Use a pair of tweezers to grip the tarped connector and lift vertically up. It may help to do this on each side of the attachment, rather than in one pull.
    • Lifting the tarped connector straight up may feel like you are breaking it, but this is normal.
  10. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 10, immagine 1 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 10, immagine 2 di 3 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 10, immagine 3 di 3
    • Pop these two connections off by using tweezers to lift straight up.
  11. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 11, immagine 1 di 1
    • Lift the screen up to fully remove.
Conclusione
Cal Poly, Team S17-G4, Livingston Spring 2018 Membro di Cal Poly, Team S17-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 258
