Introduzione
Need to access the inside of your Chromebook, but not sure what to do? This guide will show you how.
Cosa ti serve
Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
Wiggle the plate back and forth to loosen the adhesive under the plate.
Rotate the screwdriver in a counterclockwise direction to remove the screws.
Quasi finito!
Conclusione
