Salta al contenuto principale
Asus Chromebook C201PA-DS02-LG Keyboard Replacement
Cosa ti serve
  1. Asus Chromebook C201PA-DS02-LG Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Keyboard Replacement: passo 2, immagine 1 di 2 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Keyboard Replacement: passo 3, immagine 1 di 2 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Keyboard Replacement: passo 4, immagine 1 di 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: passo 4, immagine 2 di 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: passo 4, immagine 3 di 3
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Keyboard Replacement: passo 5, immagine 1 di 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: passo 5, immagine 2 di 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: passo 5, immagine 3 di 3
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
Conclusione
Cal Poly, Team S17-G4, Livingston Spring 2018 Membro di Cal Poly, Team S17-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 191
