Introduzione
If your Chromebook is not working correctly, then this guide is going to help you get your laptop working again. When working on replacing your motherboard, be sure to ground yourself. Static can short circuit your Chromebook, so be sure to either wear an anti-static wrist strap or work on a surface that doesn't generate static electricity, like wood, tile, or other hard floors.
Cosa ti serve
Flip the laptop upside down with the rear end of the computer away from you.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use tweezers to disconnect the LCD cable from the motherboard.
Altre 7 persone hanno completato questa guida.
Un commento
Hello
Where can we find this motherboard for the asus C201PA chromebook ?
