Introduzione
If your Chromebook is giving you a blank screen or messed up colors, then this guide will help you replace your screen. While following these steps, be sure to ground yourself. Static can short circuit your Chromebook, so be sure to either wear an anti-static wrist strap or work on a surface that does not generate static electricity, like wood tile.
Cosa ti serve
Flip the laptop upside down with the rear end of the computer away from you.
Altre 10 persone hanno completato questa guida.
