Salta al contenuto principale
Asus Chromebook C101P Speakers Replacement
Cosa ti serve
  1. Asus Chromebook C101P Speakers Replacement, Keyboard: passo 1, immagine 1 di 1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Speakers Replacement: passo 2, immagine 1 di 1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Speakers Replacement: passo 3, immagine 1 di 1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Speakers Replacement: passo 4, immagine 1 di 2 Asus Chromebook C101P Speakers Replacement: passo 4, immagine 2 di 2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Speakers Replacement: passo 5, immagine 1 di 3 Asus Chromebook C101P Speakers Replacement: passo 5, immagine 2 di 3 Asus Chromebook C101P Speakers Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Speakers Replacement, Speakers: passo 6, immagine 1 di 1
    • Remove the four Phillips #0 screws from the speakers.
  7. Asus Chromebook C101P Speakers Replacement: passo 7, immagine 1 di 1
    Compra
    • Remove the yellow speaker tape using tweezers.
  8. Asus Chromebook C101P Speakers Replacement: passo 8, immagine 1 di 2 Asus Chromebook C101P Speakers Replacement: passo 8, immagine 2 di 2
    • Detach the right speaker using tweezers.
    • The right speaker has its own set of cables connecting to the motherboard. Simply tug on the cables.
Conclusione
Bryan Acosta
Membro da: 10/25/19
329 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 376
