Salta al contenuto principale
Asus Chromebook C101P Screen Replacement
Cosa ti serve
  1. Asus Chromebook C101P Screen Replacement, Keyboard: passo 1, immagine 1 di 1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Screen Replacement: passo 2, immagine 1 di 1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Screen Replacement: passo 3, immagine 1 di 1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Screen Replacement: passo 4, immagine 1 di 2 Asus Chromebook C101P Screen Replacement: passo 4, immagine 2 di 2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Screen Replacement: passo 5, immagine 1 di 3 Asus Chromebook C101P Screen Replacement: passo 5, immagine 2 di 3 Asus Chromebook C101P Screen Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Screen Replacement, Screen: passo 6, immagine 1 di 2 Asus Chromebook C101P Screen Replacement, Screen: passo 6, immagine 2 di 2
    Compra
    • Detach the the screen cables from the motherboard using a pair of tweezers.
    • Peel off the tape or seal to easily remove the screen cables.
  7. Asus Chromebook C101P Screen Replacement: passo 7, immagine 1 di 2 Asus Chromebook C101P Screen Replacement: passo 7, immagine 2 di 2
    • Remove the Phillips 00 screws from the hinges.
  8. Asus Chromebook C101P Screen Replacement: passo 8, immagine 1 di 1
    • Angle the hinge as shown and use a T5 Torx screwdriver to remove the hinge screws.
  9. Asus Chromebook C101P Screen Replacement: passo 9, immagine 1 di 2 Asus Chromebook C101P Screen Replacement: passo 9, immagine 2 di 2
    • Pry open the hinge by using the iFixit opening tool.
  10. Asus Chromebook C101P Screen Replacement: passo 10, immagine 1 di 1
    • Use the iFixit opening tool to pop out the black rubber grips near the bottom of the screen.
    • Use a Phillips 00 screwdriver to remove the screws beneath the rubber grips.
  11. Asus Chromebook C101P Screen Replacement: passo 11, immagine 1 di 3 Asus Chromebook C101P Screen Replacement: passo 11, immagine 2 di 3 Asus Chromebook C101P Screen Replacement: passo 11, immagine 3 di 3
    • Use the iFixit opening tool to pry around the screen.
    • Use the space between the screen and the hinge to prop it up.
    • Once open, slide the wires that are in the hinge out. The screen should now be fully detached from the case.
Conclusione
Dan Sysopha
Membro da: 10/25/19
345 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 2,052
