Salta al contenuto principale
Asus A53U-ES21 Keyboard Replacement
Cosa ti serve
  1. Asus A53U-ES21 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Asus A53U-ES21 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Asus A53U-ES21 Keyboard Replacement: passo 2, immagine 1 di 2 Asus A53U-ES21 Keyboard Replacement: passo 2, immagine 2 di 2
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Asus A53U-ES21 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 3 Asus A53U-ES21 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 3 Asus A53U-ES21 Keyboard Replacement, Keyboard: passo 3, immagine 3 di 3
    • Remove the RAM cover from the bottom of the keyboard.
    • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
    • Work the pry tool along the edge to finish removal.
    • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
  4. Asus A53U-ES21 Keyboard Replacement: passo 4, immagine 1 di 3 Asus A53U-ES21 Keyboard Replacement: passo 4, immagine 2 di 3 Asus A53U-ES21 Keyboard Replacement: passo 4, immagine 3 di 3
    • Orient the computer so the keyboard is facing toward you with the screen at the top.
    • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
    • Use the pry tool to depress the buttons. The keyboard should pop out.
  5. Asus A53U-ES21 Keyboard Replacement: passo 5, immagine 1 di 3 Asus A53U-ES21 Keyboard Replacement: passo 5, immagine 2 di 3 Asus A53U-ES21 Keyboard Replacement: passo 5, immagine 3 di 3
    • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
    • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
    • The black piece should cover the white line on the ribbon when it is replaced.
Conclusione
Mabel Trager
Membro da: 10/23/18
147 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 490
