Salta al contenuto principale
Asus A52F Hard Drive Replacement
Cosa ti serve
  1. Asus A52F Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Asus A52F Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F Hard Drive Replacement: passo 2, immagine 1 di 2 Asus A52F Hard Drive Replacement: passo 2, immagine 2 di 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F Hard Drive Replacement, Lower Case: passo 3, immagine 1 di 3 Asus A52F Hard Drive Replacement, Lower Case: passo 3, immagine 2 di 3 Asus A52F Hard Drive Replacement, Lower Case: passo 3, immagine 3 di 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F Hard Drive Replacement: passo 4, immagine 1 di 2 Asus A52F Hard Drive Replacement: passo 4, immagine 2 di 2
    • Slide the back panel away and remove the panel.
  5. Asus A52F Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 3 Asus A52F Hard Drive Replacement, Hard Drive: passo 5, immagine 2 di 3 Asus A52F Hard Drive Replacement, Hard Drive: passo 5, immagine 3 di 3
    • Remove the four Phillips #0 screws holding the hard drive case to the laptop.
    • Lift the hard drive upwards by the two arms in order to remove the hard drive case from the laptop.
  6. Asus A52F Hard Drive Replacement: passo 6, immagine 1 di 2 Asus A52F Hard Drive Replacement: passo 6, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the cage screws on the side of the hard drive.
  7. Asus A52F Hard Drive Replacement: passo 7, immagine 1 di 2 Asus A52F Hard Drive Replacement: passo 7, immagine 2 di 2
    • Next, slide the case off of the broken hard drive.
    • Slide the working hard drive into the case and screw it on.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,594
